Date/Time: Tue, 22 Apr 2025 10:14:30 +0000
CHARTBOOK FILE IS NOT COMPATIBLE - NEED SC SUPPORT TO HELP CONVERT IT
View Count: 1083
[2022-09-10 07:05:08] |
User363681 - Posts: 3 |
Hello, Can you help converting these 3 old chartbooks that worked with older version but do not work with the latest one? |
[2022-09-12 13:48:54] |
Attached are the updated chartbooks.
[2023-03-08 17:38:40] |
joshwinks1 - Posts: 2 |
Did you get the charts to work?
[2023-03-08 22:14:12] |
For G7FX charts, you need to go to G7FX to get the updated charts.
