Date/Time: Mon, 17 Mar 2025 12:09:27 +0000
Trade Activity Log Export Problem
View Count: 389
[2022-09-10 01:21:59] |
User396 - Posts: 55 |
I cannot export trade activity statistics log information on SC 2435. I was able to export with previous version. Is anyone having the same issue with new version? File -> "Save Log as" is the only option enabled, all other options are grayed out. Thank you, |
[2022-09-10 05:20:39] |
Sierra_Chart Engineering - Posts: 18805 |
If you want to use the Export command, you need to select the first tab of the Trade Activity Log labeled "[Trade Activity]" on the menu.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-10 05:21:07
[2022-09-10 12:48:16] |
Can I export trade statistics to csv file format? was there this option available previously? thank you |
[2022-09-10 13:12:10] |
You need to use this command for that: Trade Activity Log: Saving to a Text File And the data is tab delimited. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
