Date/Time: Thu, 17 Sep 2026 11:44:40 +0000
Trying to paint the area between two Candles if there is a Gap between Low and High
View Count: 2118
[2022-09-10 00:25:52]
raheemrazzak - Posts: 41
I am using Bardifference Study with Settings
InputData1: Low
InputData2: High
InputData 1 Offset :0
InputData 2 Offset: 2
I want to draw a small rectangle between the bars if there is a gap between these two candles. With the rectangle covering the area of the gap
Currently, I'm combining this study with "Color bar based on alert condition" and adding a + sign if there is a Gap, I wanted to know if there is a way to just draw a rectangle in that area instead.
imageCurrentStudy.png / V - Attached On 2022-09-10 00:23:10 UTC - Size: 4.43 KB - 310 views
imageDesiredResult.png / V - Attached On 2022-09-10 00:23:15 UTC - Size: 3.22 KB - 260 views
[2022-09-10 03:13:20]
Sawtooth - Posts: 4354
It can be done using the Box Top Center/Box Bottom Center draw style combination in two adjoining columns/subgraphs of a spreadsheet study:
Post again if you want details.
[2022-09-10 04:37:04]
Yes please, will appreciate further details. Do you want me to make a separate post?
[2022-09-10 16:50:02]
Add the Spreadsheet System/Alert study.
- Give it a name in the Spreadsheet Name field.
- Set the Draw Style of SG5 to Box Top Center
- Set the Draw Style of SG6 to Box Bottom Center
- Formulas on the spreadsheet:
Cell O3:
=IF(D3>C5,D3,0)
Cell P3:
=IF(D3>C5,C5,0)
Column D is the Low
Column C is the High
The current bar is in row 3, previous bars in rows below.
You can duplicate this for the down direction using another two adjacent columns.
Columns K-N are for reserved for alerts. Any non-zero is a TRUE.
Alert settings in spreadsheet studies are managed on the Settings and Inputs tab, not on the Alerts tab.
You should be able to combine all of your Region 1 alerts into this spreadsheet study, if you want to.
[2022-09-11 20:39:02]
This is perfect, really appreciate your help.
One last question is there any way to change the width of the box, currently, I'm using "-1" displacement which places it right in between the candles as I perfer, but not sure if I can make it slightly wider. Not a deal breaker, just for aesthetics.
Thanks again for the help.
[2022-09-11 22:07:03]
There isn't any way to make the box wider, but you can try this instead:
Cell O3:
=IF(D3>C5,D3,0) (no change)
Cell P3:
=IF(D3>C5,C5,0) (no change)
Cell Q3:
=IF(O2>0,O2,0)
Cell R3:
=IF(P2>0,P2,0)
Cell S3:
=IF(Q2>0,Q2,0)
Cell T3:
=IF(R2>0,R2,0)
Set Draw Styles (Displacement of 0 for all):
SG5: Left Offset Box Top
SG6: Left Offset Box Bottom
SG7: Dash
SG8: Dash
SG9: Right Offset Box Top
SG10: Right Offset Box Bottom
This isn't exactly what you want, but close.
[2022-09-12 00:15:14]
Thanks @tomgilb that does the job...
Thanks @GC5150 I'll check it out
