Date/Time: Sun, 24 Nov 2024 18:40:27 +0000
Numbers Bars Calculated Values
View Count: 885
[2022-09-09 21:55:18] |
Habakuk2020 - Posts: 10 |
Hello, It is about the Study (Numbers Bars Calculated Values). Is there a way to set the calculation to the visible bars only?! How can I do this?! I have been looking for this for a long time!!! There is only the setting Daily Data or All Data Over the course of the day, I either have too much colour displayed or very little colour with All Data. How can I solve this, or is there a better option with a different study? I have made a screenshot. |
Screenshot_4.png / V - Attached On 2022-09-09 21:54:33 UTC - Size: 106.1 KB - 115 views Attachment Deleted. |
[2022-09-09 22:53:27] |
There is not an option for determining the High/Low (and hence the coloring) from the Visible Bars. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-09 23:03:15] |
Is there another way or how could I solve this? I would like the colors to only adapt to the visible bars
Date Time Of Last Edit: 2022-09-09 23:06:49
[2022-09-09 23:09:20] |
and another question, how long can it take until such a function is added
[2022-09-12 13:41:52] |
There is not another way to do this. As to when a particular capability will be added to the system, we just can not say. We have our large priority items that we are working on, and then the user requests are done as we find time to work on them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-07 17:47:29] |
Hello, I wanted to ask you after a good 1.5 years. Is it possible to implement this function in the Study? In the "Numbers Bars Calculated Values" that the calculation only refers to the "visible bars"! That would be so useful in a footprint and a really big added value, is there a possibility here please? |
