Date/Time: Fri, 18 Sep 2026 21:59:54 +0000
Historical chart with intraday session only
View Count: 1943
| [2022-09-09 21:28:44] |
| DCSaba - Posts: 124 |
On a Hisotrical Chart: is there a way to set it to only display Regular Trading Hours? This chart shows me the official Settle as it's close and would be important to see on it the Daily highs and lows, too, but without the Overnight seisson. Thank you. |
| [2022-09-09 22:52:02] |
| John - SC Support - Posts: 47939 |
You either get the full day with the settlement price, or you would get the Regular Trading Hours without the settlement price. There is no option to mix these. In order to get the RTH in a daily bar, make sure the Chart >> Chart Settings >> Data Limiting >> Chart Data Type is set to Intraday Data Only, then set your Session Times as you want and set the Bar Period to be 1 day. If you want to see the Settlement price on that same chart, then you would need to have a historical daily chart and use the Study/Price Overlay to overlay the Close of the daily chart onto the intraday chart. Refer to the following for reference: Study/Price Overlay Study Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-09 23:09:01] |
Thought I'd ask. All clear. Thc |
