Date/Time: Mon, 17 Mar 2025 12:09:28 +0000
Value of Pointer Position in the Region Value Data line
View Count: 365
[2022-09-09 15:59:39] |
Jupitersbay - Posts: 54 |
I assume it is not supported to display the value at the crosshair- or pointer-position in the region value data line - instead of the last value only? Example: To see the ATR I have to open the Tool Values Window. |
[2022-09-09 17:04:34] |
John - SC Support - Posts: 38678 |
You are correct. To see the value of a study you need to use the Tool Values Window.
