Date/Time: Wed, 16 Sep 2026 13:27:22 +0000
Can't add
View Count: 1184
[2022-09-09 15:13:31]
User933497 - Posts: 12
I found this information here in the forum:
"To make this faster and actually useful, add the Add Symbol Alert to your Chart shortcut menu via Global Settings/Customize Chart Shortcut Menu and you can select it via right click right on your chart. Your price will be the point you clicked your mouse for the alert."
However, there is no "Add symbol alert" in the customize chart shortcut menu. Can someone help?
[2022-09-09 17:02:45]
John - SC Support - Posts: 47903
The option for "Add Symbol Alert" is available to add to the Chart Shortcut menu.
It's hard to tell you where it is, but if you open that window and then click in the left side pane, where you select the options, then type 'a' on your keyboard and continue hitting the 'a' key, it will find the option within a few clicks.
