Date/Time: Mon, 17 Mar 2025 12:09:29 +0000
Cross Hair grab
View Count: 389
[2022-09-09 13:50:16]
Jaydtrade - Posts: 88
Is there a way I can make it so when I am on chartvalue/crosshair I can also grab and move the screen around? Rather than having to switch back to "hand" tool?
[2022-09-09 16:21:02]
John - SC Support - Posts: 38678
There is not a way to do what you are asking.
This may or may not work for you, but you can do the opposite, which is to have the crosshairs available when you are using the Hand tool (and other tools). Refer to the following setting for this:
Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values)
