Date/Time: Wed, 02 Sep 2026 21:37:26 +0000
Sierra Chart profile compatibility issues
View Count: 1125
[2022-09-09 12:36:35]
User897008 - Posts: 48
When I use SC 2424 with attached Sierra4.config, The control bar is working. When I update SC to 2434 or 2435, control bar is not working,just only Connection status exist, the other buttons disappeared, and cannot be added back.
Private File
[2022-09-09 12:57:31]
Sierra_Chart Engineering - Posts: 24761
This is an unusual circumstance and we know why it is happening. The font is not properly defined for the Control Bar. We will implement a solution to this.
What you need to do is go to Global Settings >> Graphics Settings >> Fonts and then select a font for the Control Bar Text.
Date Time Of Last Edit: 2022-09-09 12:58:15
