Date/Time: Tue, 18 Mar 2025 04:35:47 +0000
Current versions for both, but shared chartbook i send comes back as blank
View Count: 838
[2022-09-09 11:30:15]
HeyUgly - Posts: 251
trying to help a friend. We are both on newest sierra, i sent him a chartbook, and it comes back as blank. Data feed is correct, all his older chartbooks work fine, symbol is fine. What gives? sharing chartbooks used to be so easy. now it seems like it has a hard time for some reason. Is there a new feature that needs to be checked? the charts open but everything comes back blank charts
[2022-09-09 12:32:53]
Sierra_Chart Engineering - Posts: 18812
Make sure the symbols are correct. Have them select Edit >> Translate Symbols to Current Service when the Chartbook is open.
If there still is a problem:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2022-09-09 12:33:10
