Date/Time: Mon, 17 Mar 2025 11:28:06 +0000
All TF with the same settings for VWAP - only different result in M15
View Count: 390
[2022-09-09 10:27:26]
nicktrader - Posts: 745
I use the VWAP in H1, M15, M3 and M1. All TFs have the same setting for the VWAP.
The exact same values are always displayed in H1, M3 and M1. Only in M15 each time there is a difference of 2-3 points in the FESX (see pic). Other users have the same problem.
What could be the reason that it only affects the M15 chart?
Many thanks.
imageVWAP.png / V - Attached On 2022-09-09 10:26:09 UTC - Size: 115.49 KB - 105 views
[2022-09-09 15:50:48]
John - SC Support - Posts: 38678
If you have the Input for the VWAP for Use Underlying Data set to Yes for all the charts then they should give you the same results. This is not set in the image you provided, so we are wondering if it is only set to No on this one chart.
[2022-09-09 16:14:39]
Sorry John - My fault. You are absolutly right. M15 had a setting to NO
Many thanks. I changed it and now it works.
