Date/Time: Mon, 17 Mar 2025 11:28:06 +0000
Updated to new version and my volume profile enclosing lines are drawing different
View Count: 1115
[2022-09-09 09:37:14] |
User21243 - Posts: 48 |
Just updated to the current version and my volume profile enclosing lines are now drawing on the current price bar, and I can't seem to get it to not do it. Before the update I didn't have the enclosing line on the current price bar. I just want the enclosing line to show up on the bar in the past so I can see where I have the profile pulled to, but I do not want it to show on the current price bar -- gets in the way visually. See attached pics. Thanks |
[2022-09-09 15:38:53] |
John - SC Support - Posts: 38678 |
There was a change to how the enclosing outline is drawn in the most recent pre-release, but it just draws the "base" of the enclosing outline. In your image, you are pointing to the most recent end of the Volume Profile enclosing line, but that has always been drawn, so we do not understand what you are seeing as a change. Also, is this a Drawn Volume Profile outline that you are referring to, or the VbP study? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-09 16:30:14] |
It's a drawn Volume profile. That's weird, because before I updated to the current version (2435) I never had the enclosing line on the right side (on the current price bar). I'm certain it wasn't on there before, because I also put one on a 1 minute chart and it wasn't like this before the update. See one minute pic, also a drawn volume profile... |
[2022-09-09 17:17:30] |
Version 2430 Drawn Volume Profile: - Creating Profile: https://www.sierrachart.com/image.php?Image=166274345442.png - Editing Profile https://www.sierrachart.com/image.php?Image=1662743512153.png Version 2436: - Creating Profile: https://www.sierrachart.com/image.php?Image=1662743777272.png - Editing Profile: https://www.sierrachart.com/image.php?Image=1662744945692.png We do not see any difference in the enclosing profile between these situations. If we are missing something, please let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-09 17:35:59
[2022-09-09 18:25:41] |
Weird, near 100% certain it wasn't doing that before i updated. Is there a way that i can see which version i was using before i made the update today? |
[2022-09-09 21:59:10] |
You can change back to your previous version, which would be the fastest and easiest way, by selecting Help >> Install Previous Version.
[2022-09-11 11:35:40] |
Sierra_Chart Engineering - Posts: 18805 |
There was a recent change with this and we will make it an option.
