Date/Time: Mon, 17 Mar 2025 12:10:18 +0000
download fail error
View Count: 844
[2022-09-09 05:33:36] |
User183724 - Posts: 194 |
i'm getting a download failure error
[2022-09-09 14:28:27] |
John - SC Support - Posts: 38678 |
We need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
