Date/Time: Mon, 17 Mar 2025 12:09:30 +0000
Fail orders
View Count: 861
[2022-09-08 17:45:35] |
User491428 - Posts: 87 |
in the last two days, sierra drew wrong orders. every time. You can see this in the diagram images https://www.sierrachart.com/image.php?Image=1662658746279.png In this example I go short, a position on the tick chart draws a negative pl. also the pl window tells me a negative pl.. the correct orders are displayed in the footprint. the correct profit is also displayed in the account balance monitor. what happened here that there has been this wrong information for a few days?? https://www.sierrachart.com/image.php?Image=1662660378398.png i always delete all orders as soon as i turn off sierra. As I said, this is not the first time Date Time Of Last Edit: 2022-09-08 18:07:30
[2022-09-09 06:49:41] |
Sierra_Chart Engineering - Posts: 18805 |
This is not clear for us. However, if you are referring to the profit/loss shown with an order fill, refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities And if you are referring to the Daily Profit/Loss, refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
