Date/Time: Tue, 22 Apr 2025 18:08:46 +0000
Filter Dom Graph on Chart
View Count: 2066
[2022-09-08 17:01:16] |
kam2001 - Posts: 86 |
Hi, is it possible to add functionality to filter Dom Graph on chart to only show bars above certain number, as now you are showing over 100's levels (bars) with MBO and Dom looks all cramped up. Maybe add under chart settings > Advance Settings 2 > Dom Graph section > Only show levels above {{number}}. I know currently there are options to show greatest volume. Thanks, Kam |
Attachment Deleted. ![]() |
[2022-09-08 18:12:20] |
John - SC Support - Posts: 39416 |
We have set this as a Feature Request.
[2022-10-17 09:25:25] |
any idea of the version this feature be include in ?
[2022-12-07 16:23:38] |
Rui S - Posts: 199 |
+1 here
[2023-06-15 10:33:35] |
any updates ?
[2023-09-20 12:57:42] |
any updates ?
[2023-09-20 13:23:50] |
Sierra_Chart Engineering - Posts: 19305 |
This will be added to the next release.
[2023-09-21 14:00:18] |
stephenvosloo - Posts: 28 |
This is brilliant thank you SC Dev team! Since the functionality is built in for the DOM graph, any chance we can highlight larger resting orders in the limit order book? Say for instance we want to still see all the depth but highlight certain size above say 100 for instance?
[2023-09-21 21:20:45] |
Sure we can do that. How would you want this highlighted? A different background color or what?
[2023-09-21 22:14:39] |
Yes, that would be fantastic. Just a simple filter, > “x” amount and ability to change the background similar to how T/S works to alert large orders. If it’s not too much trouble being able to set the color of the “text” would be great as well thank you!
[2023-09-22 03:53:23] |
User852559 - Posts: 40 |
It would also be great if we could add the capability to set a maximum size threshold for the relative size of the bars. Sometimes when a large order is in the book compared to the rest of the sizes the DOM graph becomes unreadable. Allowing us to set a maximum threshold would make it much more functional in these scenarios.
[2023-10-08 12:35:13] |
Post #7: This will be added to the next release.
Just to confirm: this feature hasn't been yet implemented, correct? Or is it me that can't find its settings? Date Time Of Last Edit: 2023-10-08 12:35:56
[2023-10-30 14:58:54] |
What is asked for in post #10 has not been added yet.
[2023-11-11 18:01:53] |
User411320 - Posts: 319 |
following
[2023-12-28 15:44:57] |
any update ?
[2024-01-12 09:39:57] |
any update ?
[2024-02-22 07:08:19] |
really !!
[2024-07-02 15:11:02] |
Has this been added yet ?
[2024-07-02 16:30:14] |
Refer to the following for what has been added: Chart Settings: Chart DOM/DOM Graph: Only Display Market Depth Above/Equal Quantity (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-03 06:56:25] |
Thank you :)
[2025-01-02 21:59:31] |
User438057 - Posts: 51 |
Post 11: It would also be great if we could add the capability to set a maximum size threshold for the relative size of the bars. Sometimes when a large order is in the book compared to the rest of the sizes the DOM graph becomes unreadable. Allowing us to set a maximum threshold would make it much more functional in these scenarios. I would really appreciate this functionality as well -like- Chart DOM/DOM Graph: Only Display Market Depth Below/Equal Quantity Or more better: instead of leaving out of to large quantities to have the ability to shrink them to a smaller size(that they do not distort the DOM graph)and instead to coloring them like the Market Depth Historical Graph does. Could you please consider this to implement? |
