Date/Time: Mon, 17 Mar 2025 11:32:05 +0000
Sudden Freezing of a Chart
View Count: 381
[2022-09-08 10:59:00]
KXRCap - Posts: 64
SC -
My EuroFX 150 Volume chart has suddenly stopped creating new bars. You can see the bid/ask change but no new bars.
I created a new Chartbook and moved the Chart to this still does not work.
I deleted my data folder both .dly and .scid files reloaded and still does not work.
I also closed out and updated software still does not work.
If I open a new Chart with same symbol it works.
Chartbook is attached.
Please Advise
Konrad.
attachmentEuroFX Chart NotWorking.Cht - Attached On 2022-09-08 10:57:30 UTC - Size: 18.69 KB - 358 views
[2022-09-08 11:41:18]
Sierra_Chart Engineering - Posts: 18805
We are not seeing any problems at all with that chart:
https://www.sierrachart.com/image.php?Image=1662637130442.png
New bars are appearing based upon the volume traded.
There are a lot of studies on the chart but they are not causing any observable problem.
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
[2022-09-08 11:48:28]
KXRCap - Posts: 64
Hmm Interesting.
I just tried saving the Study Collection and opening a fully new chart and it Froze in the same spot.
I did duplicate an existing chart changed the symbol and it worked fine. Just have to adjust the parameters.
Weird....
Have a good day...
Konrad.
