Date/Time: Tue, 29 Sep 2026 08:49:18 +0000
Replay - Jump To Next Bar - Multiple Timeframes
View Count: 994
[2022-09-08 07:40:11]
Jupitersbay - Posts: 54
When you have three linked charts with different timeframes in your chartbook (Main: M5, M1, M15)
and you use Standard Replay mode / Charts with Same Link Number (or "all charts")
and you use the Replay on the M5-chart
and you click "Jump Method - To Next Bar"
Then
- the M5 chart jumps to the next bar = 5 minutes later
- the M15 chart jumps to its next bar = 15 minutes later
- the M1 chart jumpts to its next bar = 1 minute later
They are not synchronized any more.
Shouldn`t the time stay synchronized - relative to the main Replay chart?
Attached screenshot shows three charts in Replay mode after clicking 1x "JumpTo Next Bar"
imageSC Replay Timeframes.jpg / V - Attached On 2022-09-08 07:39:27 UTC - Size: 154.82 KB - 202 views
[2022-09-09 07:47:18]
Sierra_Chart Engineering - Posts: 25001
We have thought about adding support for this but the implementation is complex.
Instead, you cannot jump forward by one bar but only jump forward by a set amount of time. So you need to avoid jumping by a bar.
