Date/Time: Mon, 17 Mar 2025 12:11:14 +0000
Text popup on chart--can I disable?
View Count: 835
[2022-09-07 20:38:56]
User592023 - Posts: 9
I'm new to the program so apologies if this is too basic, but every time I touch the screen on a chart the text box (for writing notes on the chart) pops up. It's almost making the program unuseable. Is there a way to stop that or disable that popup unless I really want to make a text note on the chart? I couldn't find anything about that on teh website or support boards. Thanks!
[2022-09-08 15:44:09]
John - SC Support - Posts: 38678
You have one of the Text drawing tools selected. You just need to select a different tool under the Tools menu. The Pointer in particular, does not actually draw anything.
You may be interested in the setting described at the following link:
Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options)
