Date/Time: Mon, 17 Mar 2025 12:12:50 +0000
Time and sales on ES showing fractions on NQ showing decimals
View Count: 852
[2022-09-07 18:09:34]
Litz - Posts: 131
Never saw this before any setting available?
[2022-09-08 15:06:34]
John - SC Support - Posts: 38678
We are not sure exactly what you are seeing, but it sounds like your Chart >> Chart Settings >> Symbol >> Price Display Format is not set correctly for these charts.
If this is not it, then we need to see an image of what you are seeing.
[2022-09-08 15:34:44]
Litz - Posts: 131
Ok found out I had an old version installed that had no price display format option Tnx
[2022-09-08 15:57:56]
Sierra_Chart Engineering - Posts: 18805
The Price Display Format exists in all versions.
[2022-09-08 16:10:39]
Litz - Posts: 131
ok I could not find it in my old version setting/symbol only shows find maybe i looked in wrong place whatever tnx for the reply
