Date/Time: Mon, 17 Mar 2025 11:30:23 +0000
Concurrent Logins
View Count: 893
[2022-09-07 16:55:12] |
User993067 - Posts: 174 |
Hello, Currently my setup is 2 machines...I pay for concurrent connection with my broker AMP machine 1 is charting only..CQG data...and I still use MC, because many of my studies are in EL and I have yet to convert the code. machine 2 is order placement SC with denali feed... Question I am sick of MC issues...forcing myself to migrate over to SC fully, can I do this with same 2 machine setup, using SC for both connections concurrently..each time i try to do this I am kicked off the 1st machine...amp credentials are supposed to be interchangeable between platforms...have 2 separate... please explain if 2 machine setup is possible...i use a lot of VP/footprint charts I do not want execution to be questioned from cpu usage... |
[2022-09-08 00:39:08] |
John - SC Support - Posts: 38678 |
Yes, it is possible, but you need to pay the exchange fees twice. Refer to the following information/instructions: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-08 02:37:06] |
Thank you, I am currently paying two sets of exchange fees with the concurrent logins. However, I pay once with my broker for CQG data and multicharts, and again with denali feed in my subscription. So to be clear...if I am to fully migrate over to SC for both machines I would need to cancel the CQG data through broker and pay the 2nd set of CME fees directly through SC? ie if I use SC twice I pay twice through SC? |
[2022-09-08 06:45:43] |
Sierra_Chart Engineering - Posts: 18805 |
I would need to cancel the CQG data through broker and pay the 2nd set of CME fees directly through SC? Yes. If you will be using Sierra Chart on two computers at the same time and you want real time CME data on those computers.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-08 06:46:26
