Date/Time: Mon, 17 Mar 2025 12:12:49 +0000
Global Settings Menu Item
View Count: 881
[2022-09-07 15:31:05] |
denarius - Posts: 16 |
I want to reorder the chartbooks that appear when I open Sierra Charts. In the past (version 2276) I would go to Global Settings and select General Settings and I would have a list of the tabs of the chartbooks that open - and it was easy to add / delete / re order the chartbooks. Now I have version 2425 and I don't see under General Settings how I do this now. So what do I do to change the chartbooks that open up on start up? I attach a copy of my setup - I want to make some changes to the line Quote Board - ATR - Indices Dly 240 etc Thank you. Richard |
[2022-09-08 00:25:52] |
John - SC Support - Posts: 38678 |
The option for automatically opening chartbooks is largely the same, just in a different location. It is under Global Settings >> General Settings >> General >> Open Files on Startup where you can set Yes or No to automatically open the files. And right below it is a Button that states [Select Files to Open on Startup]. Select that button to open the window where you set the chartbooks to open. Refer to the following: General Settings Window: Select Files to Open On Startup (Global Settings >> General Settings >> General >> Startup) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-08 00:26:25
