Date/Time: Mon, 17 Mar 2025 11:30:22 +0000
Globex futures live data starts charting at 7:30 am est instead of much earlier
View Count: 907
[2022-09-07 13:32:31]
paul gierer - Posts: 18
Globex futures live data starts charting at 7:30 am est instead of much earlier at the start of the new day The data is live (correct)
[2022-09-07 17:18:43]
John - SC Support - Posts: 38678
We are not sure what the question is here.
If you are stating that the Session Times are incorrect, then you can change them for your individual charts within the Chart settings (Chart >> Chart Settings >> Session Times).
If you want to change them generally for the symbol, then you would need to make this change in the Symbol Settings. Refer to the following:
Global Symbol Settings: Instructions
[2022-09-08 12:24:27]
Problem solved I downloaded vers 2434 interestingly I never had a problem with historical until yesterday
[2022-09-09 08:56:09]
Sierra_Chart Engineering - Posts: 18805
Check the Session Times:
Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time
