Date/Time: Mon, 17 Mar 2025 12:10:20 +0000
changing fonts and numbers size in x/y scale
View Count: 1226
[2022-09-07 06:20:16] |
User525268 - Posts: 5 |
Hello! I want to know how to increase the size of the numbers that appear on the price scale and also the time numbers in the timeline, and also different texts that appear on the chart, such as buy/price, etc. It's very small and I can't see them! please help me with that 'I searched and couldn't find it anywhere. Thanks for the help Ari |
[2022-09-07 16:52:47] |
John - SC Support - Posts: 38678 |
The sizes of the various items in Sierra Chart are controlled through the Fonts tab on the Graphics Settings window. Refer to the following: Graphics Settings: Fonts and Text Appearance Studies, however, tend to be different and have their own settings within the Subgraphs or possibly in the Inputs. It depends on the individual study and the item you are trying to change. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-07 17:43:44] |
Sorry, I tried this with all the options but the font on the price and time scale size didn't change!
[2022-09-08 14:03:09] |
The Price and Time scales are controlled by the "Chart Text" font. If changing this does not affect the chart, then you need to use the other Graphics Settings option. Keep in mind that you can use either Global Graphics Settings or Chart Specific graphics settings. If you are changing the global option (Global Settings >> Graphics Settings) and the graphics are not updating, then the chart must be setup to use the Chart specific graphics. In which case you need to select Chart >> Graphics Settings - Chart. For more information on chart graphics settings versus global graphics settings refer to the following Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
