Date/Time: Mon, 17 Mar 2025 12:10:18 +0000
chart scale text color
View Count: 1307
[2022-09-06 19:49:04]
Gtrader510 - Posts: 75
hi im having problem changing scale text color please help.
image2022-09-06 12_42_48-#5 F.US.EPU22 V_ 99, 0 CV_ 99, 0.png / V - Attached On 2022-09-06 19:48:06 UTC - Size: 30.91 KB - 170 views
[2022-09-06 19:50:11]
also when i chose global setting it shows the scale text i tried changing color but it's not working
[2022-09-06 22:24:54]
hello please help
[2022-09-07 16:30:32]
John - SC Support - Posts: 38678
In newer versions, the text color for the values scale is controlled by the Graphics Setting for Chart Values Scale Text Color. In older versions it is controlled with the Chart Text setting.
If you are changing the setting for Chart Values Scale Text Color and it is not having an impact, then that chart must be setup to use the Chart Graphics setting, rather than the Global Graphics Settings. In which case, you want to select Chart >> Graphics Settings - Chart and then make the changes there.
Refer to the following for information on the Graphics Settings:
Graphics Settings
