Date/Time: Mon, 17 Mar 2025 12:10:18 +0000
how to leave space to the right of the chart
View Count: 858
[2022-09-06 19:04:10]
ephi144 - Posts: 54
i have already tried "number of forward columns" setting but i can t get more room to the right of the chart.
imageSC_screen.png / V - Attached On 2022-09-06 19:03:45 UTC - Size: 114.59 KB - 101 views
[2022-09-06 21:53:52]
bootsy - Posts: 63
Am not logged on at the moment but there is a Lock Fill Space function near the top of the Charts (or maybe it's Tools?) drop down menu.
Make sure Lock Fill Space isn't ticked and press the right hand chart scroll bar to inch the chart across the screen to increase the amount of room to the right of your chart.
When you've got enough space then go back to Lock Fill Space option and click on it so there's a tick next to it.
[2022-09-06 22:01:47]
ephi144 - Posts: 54
thank you!! that works
