Date/Time: Tue, 18 Mar 2025 02:25:46 +0000
I am new to the Sierra chart
View Count: 824
[2022-09-06 18:48:48] |
User794174 - Posts: 1 |
I am new , can you check that if anything missing . What do I need to do to fix it . Thank You |
[2022-09-07 15:07:27] |
John - SC Support - Posts: 38735 |
What is not working? What are you expecting that is not occurring?
[2022-09-09 08:13:52] |
Sierra_Chart Engineering - Posts: 18812 |
Refer to the Getting Started page: Getting Started, Opening Charts and Basic Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
