Date/Time: Mon, 17 Mar 2025 12:09:29 +0000
Linear Regression Channels
View Count: 840
[2022-09-06 17:13:04] |
User703411 - Posts: 19 |
Hi, I use the Study/Price Overlay study to copy Linear Regression End Channels from a 15 second chart to a 30 minutes numbers bar chart. However, as the 30m session progresses I loose the visability of the channel lines which after 5-10 mintues are nothing more than small dots. At the start of the 30m the lines are fine. How can I fix this? Thanks, Alan. |
[2022-09-06 22:48:53] |
John - SC Support - Posts: 38678 |
Please attach a chartbook with those two charts in it so we can see how you have this setup. Refer to the following instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
