Date/Time: Tue, 23 Jun 2026 10:02:49 +0000
Extending Rectangle with "Prompt for Text"-option + Closing Textwindow with Ctrl+Return
View Count: 1066
| [2022-09-06 15:32:41] |
| Jupitersbay - Posts: 54 |
It would be great to have a "Prompt for Text"-Option in the Extending-Rectangle-Tool. When you are using this tool to draw supply/demand-zones that stay in the chart for a couple of days, the label can be EXTREMELY helpful. The way to create a descriptive label by clicking and clicking and chosing "modify text" ... and clicking again ... ... is a bit cumbersome. Maybe you want to consider to integrate a "prompt for text"-option. Additionally I would suggest to add the option to close the text-tool-window by using Ctrl+Return. So it would not be necessary to grab for the mouse just to close the text-window after writing in the text-window (where you usually have your hands on the keyboard) |
| [2022-09-06 22:35:00] |
| John - SC Support - Posts: 46822 |
We have set this as a Feature Request.
