Date/Time: Tue, 18 Mar 2025 02:25:46 +0000
Market Replay paused still showing CPU load..
View Count: 916
[2022-09-06 15:09:19] |
User414533 - Posts: 106 |
I'm running Market Replay with 3 indices and I'm noticing that the CPU is still working hard (15-20%) even though the replay is paused. This never happened before when I was only running one index. Any ideas? -Only one chartbook is open -Replay control panel set to "all charts in chartbook" |
[2022-09-07 10:54:31] |
Sierra_Chart Engineering - Posts: 18812 |
This could be caused by studies which are causing the chart to be continuously redrawn. Refer to help topic 30.14: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.14 - Display Continuous Time Countdown (CountDown Timer) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-07 17:57:13] |
I have that set to no. Would you like my chartbook file? |
[2022-09-07 18:02:35] |
No, we do not look at Chartbook Files for reasons like this. You just need to close each chart and see which one is causing the problem. Also refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-07 18:02:40
