Date/Time: Mon, 17 Mar 2025 11:28:03 +0000
Market data
View Count: 824
[2022-09-06 15:05:14] |
User990654 - Posts: 6 |
Hi, 1/I trade a Transact account (Infinity Futures) 2/I trade a Leeloo account too 3/I need to know EXACTLY which data is needed for both instances 4/Which package (Market Profile/TPO needed) Thank you for your kind attention. Best Regards, DL. |
[2022-09-07 15:59:43] |
Sierra_Chart Engineering - Posts: 18805 |
You will need Service Package 11: Description of Service Packages and Pricing: Integrated Packages And you need to use the Denali Exchange Data Feed: Denali Exchange Data Feed You will want to install two separate installations of Sierra Chart, one for each service: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-07 16:00:00
