Date/Time: Mon, 17 Mar 2025 12:11:11 +0000
Cutsom Values in
View Count: 838
[2022-09-06 15:00:00] |
Jupitersbay - Posts: 54 |
I assume it is not supported to add custom values to the table of "Number Bars Calculated Values"? It would be a nice-to-have, if you added 3 lines with the option of adding values from other studies to the table. Thank you. |
[2022-09-06 22:06:24] |
John - SC Support - Posts: 38678 |
We have set this as a Feature Request. There have been other requests for this as well. Note that you can create you own table using our custom study interface. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
