Date/Time: Tue, 26 Nov 2024 13:28:59 +0000
проблемы с символами
View Count: 1223
[2014-05-14 21:18:12] |
Nigra - Posts: 1 |
загрузил версию 1137 триал. поставщик котировок cts t4 сим. выглядит все вот так http://SSMaker.ru/23bcb16e/ тикеры не загружаются. если я правильно понимаю то должно быть вот так http://SSMaker.ru/0ba920be/ В чем может быть проблема? |
[2014-05-15 08:37:48] |
We see in one of these images that there are 2 6E symbols listed. What you need to do is perform a Full Reset of the symbol settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps This will remove the old symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-15 08:38:04
