Date/Time: Mon, 17 Mar 2025 11:30:20 +0000
Same instrument, Multiple strategies
View Count: 1190
[2022-09-06 08:43:18] |
User575910 - Posts: 16 |
Hey there, I'm wanting to deploy a secondary strategy whilst simultaneously trading my current strategy on the same instrument MES - one to be a short term scalp strategy and one being swing trading (my current strategy). Is it possible to do this by opening a new chartbook or will it interfere with my swing trade - i.e flatten my swing trade ?? Many thanks Dean |
[2022-09-07 16:00:32] |
Sierra_Chart Engineering - Posts: 18805 |
Refer to: Automated Trading Management: Using Multiple Automated Trading Systems at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
