Date/Time: Tue, 22 Sep 2026 08:44:54 +0000
Attached orders moving after parent order is filled
View Count: 1394
| [2022-09-06 04:06:48] |
| PolandSpringer - Posts: 33 |
I have a basic order configuration with 1 target and 1 stop. Typically I use the attached order and submit it, making adjustments on the stop & take profit using the drag and drop feature on the chart. When my parent order gets filled the stop and take profit attached orders are moving back to their default state when submitted (configured for +5pts TP, -5pts stop). Why is this happening? Does this have to do with the scale in/out feature? |
| [2022-09-06 06:42:40] |
| Sierra_Chart Engineering - Posts: 24928 |
You need to disable this option: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
