Date/Time: Mon, 17 Mar 2025 11:32:04 +0000
Denali - Active Exchange: NASDQ US STocks Data
View Count: 867
[2022-09-06 02:24:23] |
usgvince - Posts: 23 |
I have the Denali Active Exchange for NASDQ US Stocks. I also have Active Exchange: US Equities (NYSE, NASDQ, AMEX and Exchanged Data Feed: 250 Real Time Symbols (First Connection) I think I can get rid of US Equities and the Exchange Data Feed cost when I have the Denali Active Exchange. Is this correct or am I missing something. Thanks |
[2022-09-06 21:12:13] |
John - SC Support - Posts: 38678 |
In general, you would only need one of these exchanges, but there are some differences between them, and depending on what you need, you might find having both to be beneficial. Here are the differences: - Sierra Chart Exchange Data Feed with U.S. Equities exchange: Does NOT have market depth information, but does have consolidated tape (full volume from all exchanges on which an instrument trades). - Denali Exchange Data Feed with NASDAQ TotalView exchange: Has market depth information, but does not have the consolidated tape (only has volume from the primary exchange for an instrument). We are working on getting the consolidated tape for the NASDAQ TotalView exchange on the Denali Exchange Data Feed, but we are not done with this yet. Therefore, it is your choice as to whether to use one or both. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
