Date/Time: Mon, 17 Mar 2025 02:42:19 +0000
Release Note for Version 2424
View Count: 397
[2022-09-05 16:27:26] |
Tony - Posts: 554 |
Hi, The release note says: It is now supported to change the trade Order Quantity within the chart with the following keyboard entry: OQ[quantity].
It is a very handy feature. Sorry, I couldn't figure out what exactly I should do, I tried key "O" "Q" and number, also "Alt"+"Q" + number, they had no effect.. Thanks so much. |
[2022-09-05 19:13:40] |
Sierra_Chart Engineering - Posts: 18801 |
Yes this does work. For example you can enter OQ5 and press the enter key to change the order quantity to 5. We tested this and it works.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-05 19:13:51
