Date/Time: Mon, 17 Mar 2025 02:36:49 +0000
DATA ISSUES
View Count: 343
[2022-09-05 09:18:02] |
NICOLAS BELVITO - Posts: 1 |
Hi, An issue occurred yesterday as follow : Edit/Download Data/Intraday Chart Since then, a lot of data is missing throughout the charts... I've tried several times to repeat the operation with no success. Could you help, please ? Thanks so much for your kind attention. Regards, Nicolas. |
![]() Attachment Deleted. |
[2022-09-05 14:16:47] |
Sierra_Chart Engineering - Posts: 18801 |
You are using Rithmic. This is a Rithmic market data issue. We cannot help with Rithmic market data issues. We strongly recommend using the Denali Exchange Data Feed. Refer to: Rithmic Trading Platform Service: Rithmic Support Policy Let us know if you would like help setting up the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-05 14:17:21
