Date/Time: Mon, 17 Mar 2025 01:10:26 +0000
Study/ Price Overlay
View Count: 405
[2022-09-05 04:43:00] |
nicktrader - Posts: 744 |
The study "Study/ Price Overlay" causes these messages Chart #10 has tagged chart #2 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.081 Chart #10 has tagged chart #3 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.081 Chart #12 has tagged chart #1 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.055 Chart #12 has tagged chart #2 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.055 Chart #12 has tagged chart #3 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.055 Chart #12 has tagged chart #4 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.055 Chart #9 has tagged chart #1 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.089 Chart #9 has tagged chart #3 for full recalculation. Chartbook: 000 FESX_08U22.Cht | 2022-09-05 06:36:12.089 Is there any way to change that? Many thanks |
[2022-09-05 14:27:09] |
Sierra_Chart Engineering - Posts: 18801 |
This is not unusual. However, if this continuously occurs, refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.9 References to Other Charts / Continuous Full Recalculation of Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-05 14:27:19
[2022-09-06 10:28:09] |
This occurs each morning when I start the platform. I do have the following "problem". Some time ago I suggested to add the option "Extend...until Future..." to the study "Volume Value Area Lines" for all three SG. The big advantage of this study is that you can e.g. view the data from M15 in a M3 Chart. Unfortunately, you have not recognized the necessity until today. So I had to come up with another (quick&dirty) solution. For three TF that I use daily, I created 3 charts with the same TF with NumberBars and from there I take only the naked POCs with the Study "Study/ Price Overlay". This is not a " proper " solution, because it is very time consuming, but it works. But it would be much much easier if you could add the above mentioned option into the Study "VALines" Many thanks |
