Date/Time: Sun, 22 Dec 2024 18:24:17 +0000
Order Fill Triangles on Chart
View Count: 1633
[2014-05-14 19:09:15] |
infpz - Posts: 826 |
Can they be increased in size?
[2014-05-15 01:21:23] |
No. They are automatically set but we can add this capability.
[2014-05-15 11:09:32] |
Thank you, please update this post if you add this capability.
[2014-05-15 12:02:17] |
User63439 - Posts: 83 |
+1 from me
[2014-05-15 15:37:19] |
Marek F - Posts: 244 |
+1
[2014-06-04 12:48:59] |
Hello, just checking to see if this is possible yet.
[2014-06-04 17:35:47] |
Not yet.
[2015-05-08 17:33:58] |
Hieronymus - Posts: 51 |
My triangles are huge and I'm not sure how they got like that.. there must be a way to change the size.
bigtri.png / V - Attached On 2015-05-08 17:33:22 UTC - Size: 296.27 KB - 408 views |
[2015-05-08 17:44:30] |
User52989 - Posts: 42 |
+1 HATE the tiny triangles
[2015-05-08 17:45:59] |
That's funny because I want them! I don't know how to get them small again.
[2015-05-09 01:35:29] |
This can be changed with: Global Settings >> Chart Trade Settings >> Fill Marker Size Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
