Date/Time: Mon, 17 Mar 2025 02:42:20 +0000
Charts No Longer Remember Location of Quoteboard
View Count: 334
[2022-09-02 23:40:34] |
cmet - Posts: 680 |
Since upgrading to 2430, the location/size of the Quoteboard is no longer remembered in my layout. It is shrunk down and moved to my main screen. Has to be resized and moved every single time I open SC. Is there a fix for this extremely annoying issue? Thanks. |
[2022-09-03 08:16:42] |
Sierra_Chart Engineering - Posts: 18801 |
This is resolved in version 2432. Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-03 08:16:46
