Date/Time: Mon, 17 Mar 2025 01:18:39 +0000
Hey support just can't select and adjust any volume by price drawings
View Count: 329
[2022-09-02 21:22:28] |
Francis Pelletier - Posts: 3 |
Hey. It's been 4 days that I try to find ANYWHERE some video or thread or anything helping me with this issue. I just CAN'T select anything drawn on my chart and adjust it. What is the problem with this? PLEASE HELP ME!!!
[2022-09-02 21:40:02] |
John - SC Support - Posts: 38678 |
First, is it any drawings at all, or just the Volume by Price drawings? Assuming that it is just the Volume by Price drawings, then make sure they are actually Drawn Volume Profiles, as you can not select volume profiles that were created from the study. Then refer to the following: Volume By Price Study: Modifying Manually Drawn Volume Profile You may also want to take a look at the option for Support Left Click to Select Chart Drawings and Select Drawn Volume Profile by Outline Only. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
