Date/Time: Tue, 26 Nov 2024 18:18:23 +0000
Automatically set VWAP to start at the same time daily
View Count: 537
[2022-09-02 21:05:00]
Radu Sirbu - Posts: 40
Hi guys,
I couldn't find an easy way to set VWAP to start at a specific time each day, not necessary at the session open.
I found one way to do this, but it is not user friendly at all.
I use the Volume Weighted Average Price study where, daily, I have to set the Date for today and the time that I'm interested in. I don't understand why there isn't a setting here where you can simply just check "daily" or "today" without specifying the date.
Thanks,
[2022-09-02 21:30:55]
John - SC Support - Posts: 36300
The easiest way to do this is to use the Volume by Price study and set the following:
- Draw Mode: POC, VAH, VAL, VWAP
- Ticks per Volume Bar: 1
- Volume Graph Period Type: From Start Time to End
- Start Time: [Desired Start Time]
Then in the subgraphs, set the POC, VAH, and VAL to Ignore so you just have the VWAP line.
