Date/Time: Tue, 18 Mar 2025 08:53:38 +0000
Which service package?
View Count: 626
[2022-09-02 20:26:42] |
User145060 - Posts: 4 |
I would like to do an Apex Trader Funding evaluation (rithmic data) using Sierrachart DOM and TPO charts. Do I need service package 11 for this?
[2022-09-02 21:06:52] |
John - SC Support - Posts: 38735 |
You would need either Package 10 or 11. It depends on whether you need the Advanced Features or not. Refer to the information here: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-22 10:52:44] |
User827701 - Posts: 3 |
Hi, What is Advanced Features ? What is different between package 10 vs. 11 ? Package 11 mean, that I can trade from the chart and DOM and I canĀ“t with package 10 ? |
[2022-09-22 14:57:45] |
The differences in the packages is defined at the following link: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-22 16:29:33] |
Ok. So if I want trade order flow / numbers bars, will need package 11. Right ?
[2022-09-22 16:37:39] |
Yes, you would need Package 11 in order to have access to the Numbers Bars study.
