Date/Time: Mon, 17 Mar 2025 01:10:26 +0000
Pulling/Stacking bars in DOM
View Count: 363
[2022-09-02 19:05:07]
rondawes - Posts: 39
So in a DOM,
I set up columns for pulling/stacking.
I set the colors as desired.
I enable the bar for pulling/stacking.
When there is stacking, the bar shows with the color selected. But when there is pulling, the bar is at 0 and does not show although the text number does show a negative value, i.e. -20.
How do I also get a pulling bar to show with a different color than the stacking bar? I must be missing something.
[2022-09-02 19:42:37]
John - SC Support - Posts: 38678
You are not missing anything, the volume bars for the Pulling/Stacking are not setup to show the negative values. This is something we want to change, we just can't say when we will get to it.
[2022-09-02 20:37:11]
OK, thanks. I hope it's sooner rather than later.
