Date/Time: Mon, 17 Mar 2025 18:28:08 +0000
Storage Memory Issue
View Count: 1501
[2022-09-14 19:26:43]
Steve Leon - Posts: 312
No the Global Settings were checked.
I was able to resolve the problem yesterday. Not sure what was different than previously.
I copied the Sierra4.config file from my main instance into my subinstances and overwrote the old file ? I thought i did this a couple of times previously ??? maybe the file was somehow different than the one i was copying ? who knows ?
1) The only thing I am trying to retrieve without rebuilding it is my keyboard shortcuts ? they seem to be erased ? does that make sense ? or are they part of the Sierra4.config file ?
2) In the future. If I create and save a global graphics setting in my main instance, will that show up in the global graphics settings of my subinstances ? If not what is the best way to transfer that information over to the subinstance ?
Also going in reverse, what is the best way to "transfer" a global graphics setting that is saved in the subinstance to the main instance ?
Thank you
[2022-09-14 19:38:01]
ForgivingComputers.com - Posts: 1028
Make sure you exit out of all instances before copying files.
[2022-09-14 20:56:51]
Good point
Thank you
