Date/Time: Sat, 19 Apr 2025 12:00:26 +0000
Using 2 Trading Accounts at separate Brokers
View Count: 966
[2022-09-02 18:40:37] |
User167296 - Posts: 7 |
Hello, I have two trading accounts one with AMP and the other with Stage5. Do I have one subscription or 2 subscriptions? what will be the monthly amount? Is it possible to place a single order for the 2 accounts simultaneously and what would be the procedure. Looking forward to reading from you. Cordially Translated from: <Bonjour, J'ai deux compte de trading un chez AMP et l'autre chez Stage5. Est ce que j'ai un abonnement ou 2 abonnements ? qu'elle sera le montant mensuel ? Est 'il possible de passer un seul ordre pour les 2 comptes en simultané et qu'elle serait la marche suivre. Dans l'attente de vous lire. Cordialement> |
[2022-09-02 19:13:54] |
John - SC Support - Posts: 39362 |
You only need to have the one Sierra Chart account in order to trade both of your trading accounts. Since these accounts are using different order routing systems, we recommend using 2 installations of Sierra Chart on the same computer. This will allow you to connect one installation to one trading account and the other installation to the other trading account. There are no additional costs for doing this. Refer to the instructions for how to install a second Sierra Chart here: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Once you have both installations done, then you will follow the following instructions to setup one Sierra Chart to connect to your CQG (AMP) account (if you have not already done so): CQG Trading Platform Service: Setup Instructions And then you will follow through the instructions to setup the other installation to use the Teton Order Routing Service (we assume you are setup with the Teton Order Routing with Stage 5) starting at step #6: Sierra Chart Teton Futures Order Routing: Setup Instructions Is it possible to place a single order for the 2 accounts simultaneously and what would be the procedure.
It is not possible to do this at this time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-05 01:18:16] |
Ticks - Posts: 206 |
It is not possible to do this at this time. An SC developer has a study that will provide you the ability to trade with multiple brokers with multiple trading accounts at each broker. https://www.simplesystemtrading.com/local-trade-copier/ |
[2022-09-05 15:50:55] |
Bonjour, Merci pour vos réponses. J'ai une autre question, sachant que j'ai 3 mois avec téton est ce qu'il faut que paye pour CQG ? J'ai eu un prélèvement. Dans l'attente de vous lire. |
[2022-09-06 14:09:48] |
Sierra_Chart Engineering - Posts: 19276 |
The service package that you currently have with Sierra Chart expiring on 2022-12-06 can be used with CQG.
