Date/Time: Mon, 17 Mar 2025 01:16:02 +0000
Two Questions
View Count: 317
[2022-09-02 15:35:14]
User266447 - Posts: 270
I will use AMP and get CQG/EUREX data. Which is the latest Sierra Chart version I can install on my PC in order to be supported with AMP/CQG/EUREX.
Secondly, how can I switch to CQG charts on SC. Could you remain me, please?
[2022-09-02 18:45:05]
John - SC Support - Posts: 38678
We highly recommend using our EUREX data, which will allow you to use the current release and be able to trade through CQG. Refer to the Setup Instructions for the Denali Exchange Data Feed here:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
But, if you want to use the CQG EUREX data, then you would need to be on version 2393 or lower.
If you need to downgrade your software, then follow these instructions:
Software Download: Full Control Rollback Procedure
Refer to the instructions here:
CQG Trading Platform Service: Setup Instructions
