Date/Time: Mon, 17 Mar 2025 02:36:48 +0000
Multiple T&S not showing same data
View Count: 313
[2022-09-02 15:15:25] |
User153286 - Posts: 56 |
I have 3 T&S displayed. I included an attached image to show these. The left one filters on volume >=1, the middle one filters on volume >=10 and the right side one filters on volume >= 20. All three highlight when volume is >=50. All three combine records with "Same Price and Type". Notice in the attached image that the one filtering with volume >=1 illustrates trades the other 2 miss. In the attached image, I would expect the 3 highlighted volumes to appear in all three. Also notice other volume values such as the 22 value (6 rows down in left T&S) does not appear in either of the others. Why would this occur? |
[2022-09-02 15:31:14] |
Sierra_Chart Engineering - Posts: 18801 |
You need to disable combining. Using the combining option is what is misleading you. In the attached image, I would expect the 3 highlighted volumes to appear in all three. No it does not work that way. If you read the documentation the filtering occurs before combining.
[2022-09-02 16:27:05] |
tks, that resolved the issue
