Date/Time: Mon, 17 Mar 2025 02:42:19 +0000
Open to Close Boxes in Numbers Bars Not Responding to Color Settings
View Count: 383
[2022-09-02 14:23:56]
User923944 - Posts: 8
I have followed these instructions to set open marker up box color to green, and close marker down box color to red.
Numbers Bars: Open Marker / Up Box Color
Numbers Bars: Close Marker / Down Box Color
However, all the bars are showing red, including those which are clearly up bars. Can you suggest another global or numbers bars setting I might have inadvertently selected to cause this to happen? Any other suggestions?
[2022-09-02 18:36:13]
John - SC Support - Posts: 38678
Most likely you have your chart set to a Point and Figure. In which case, the following applies:
"In the case of when using Point and Figure XO Graph Draw Type for a chart, this will affect the display of the Open and Close Marker Style. Therefore, you should use Candlestick instead."
The statement above is from the documentation at the following link:
Numbers Bars: Open and Close Marker Style
