Date/Time: Wed, 27 Nov 2024 10:36:11 +0000
[Locked] - Linux: Extremely slow data-downloads
View Count: 1271
[2023-07-21 08:25:45] |
VLiviu - Posts: 223 |
Reinstalled wine64-development and now works :D download as normal |
[2023-07-21 10:32:03] |
Wanted to share the attached info. Theme URL: https://www.deviantart.com/tonny86/art/OxygenBlack-VS-276445990 |
SierraChart-wine-dev-black.png / V - Attached On 2023-07-21 10:32:00 UTC - Size: 739.56 KB - 190 views |
[2023-07-23 16:21:01] |
Sierra_Chart Engineering - Posts: 17191 |
This is interesting. So you are getting good data download performance now when using the latest Sierra Chart version, and under Wine? What version of Sierra Chart you running? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-23 16:21:06
[2023-07-23 17:24:07] |
I'l get back to you, i'm not at home right now. (click the attached above) |
[2023-08-17 06:46:21] |
User128695 - Posts: 10 |
I'm getting similar issues, very slow chart download all of a sudden, re-installing wine64-development didn't help.
[2023-08-17 13:38:07] |
We can only refer you to this post about this: Resolution of Poor Network IO Performance under Linux/Wine And: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
